Home > Faults & Fixes > Help multiple faults
virdi0
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
I had just driven 112 miles with no problem. But when I stopped to book in I left the car running. When I came back to the car I had these faults up on the dash. A new alternator and battery was fitted 2 days before.
Post #491595 Wed Mar 23 2016 4:58pm
This is only a suggestion, but if you have just had new alternator and battery fitted, I think I would check that all connections and battery terminals are tight first.
col
Post #491606 Wed Mar 23 2016 7:01pm
virdi0
All connections are tight. Green flag did the battery test and ok. Charging and holding a charge. The speedo also stopes working. Can you swop the hight sensors from right to left? Just so I can rule out a faulty sensor. Thanks
Post #491615 Wed Mar 23 2016 8:05pm
DrRob
Perhaps get Geoff (site sponsor and mechanic) to read the codes for you. Modern cars rely on codes being read to get an idea of the problem Thumbs Up Visitor from fullfatrr.com
Post #491619 Wed Mar 23 2016 8:41pm
virdi0
Just an update. I had the wheel liners off and wd40 all the plugs. I also had the solanod block apart cos the front dropped over a few days. It's now fixed. All warning lights are out and suspension is working as it should.
Post #491717 Fri Mar 25 2016 1:12pm
DrRob
Thumbs Up Thumbs Up Visitor from fullfatrr.com
Post #491721 Fri Mar 25 2016 2:07pm
