![]() | Home > General > Whistle when accelerating afte cam belt change |
Inlet housing not attached to the throttle body correctly would be my initial thought.
Dave P Member Since: 24 Feb 2016 Location: London Posts: 4 ![]() ![]() ![]() |
Thanks for the reply.
This turned out to be a socket that had been dropped into the turbo by an idiot. |
tom0311 Member Since: 01 Apr 2016 Location: witney Posts: 240 ![]() ![]() ![]() |
Wow. That's terrifying. How long were you running it with that in there? |
That is unbelievable, the person should at least be on a serious warning, lucky not to be sacked.
deano_123 Member Since: 13 Aug 2015 Location: Newcastle Posts: 108 ![]() ![]() |
Are the blades shagged? Wouldnt be surprised if debris got into the engine |
IMO they should be replacing the turbo for free. Absolutely shocking! |
I ran for a couple of hundred miles and the result was a new turbo that was replaced by the dealer.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Kind of brings home how important it is to find a reputable mechanic.
Even with something as simple as seat covers when they drive your pride and joy into the works. Not all do!!! John
The first thing I do when I am doing the belts is as soon as I remove the air pipe, I stuff a big rag in the pipe so nothing can fall down.
