Home > Technical > Engine not turning over but battery ok |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 |
I would say the battery is U/S, nothing to do with fuel.
Thu Mar 03 2016 8:50pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
If the breakdown guy kept pressing the start button and it just kept clicking then suddenly turned over and started then I would say it could be a starter problem ie a bad connection.
Thu Mar 03 2016 9:53pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
That breakdown guy should not be let loose on a dinky toy never mind a proper car..you have a bad connection, or bad earth, nothing to do with fuel..
Thu Mar 03 2016 10:02pm |
Pappsie Member Since: 14 Feb 2016 Location: Devon Posts: 13 |
You could try the old put headlights on then press starter if headlights dim then your battery is shot, if they don't dim then battery is fine and you either have a sticking starter or a bad connection. |
Thu Mar 03 2016 10:15pm |
Well had another better read of your post and have some questions.
Fri Mar 04 2016 7:20am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 |
Thanks for all the comments guys,,I was a bit dubious Regards the comment he made about fuel,. as Flack has also rubbished his comments i think I will forget that line thought. Trouble was I was in Dubai when all this was going on so been trying to piece together info from my son. Apparently he did have a jump starter when trying to start it which made no difference so I can see his point when saying the battery is ok, in fact the battery has not been charged since all this happened and it been starting fine,,,, proper whizzes over when cranking.
Fri Mar 04 2016 7:52am |
Definitely connections.
Fri Mar 04 2016 9:26am |
