![]() | Home > Faults & Fixes > Sat Nav not displaying correctly? |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Maybe the antenna is faulty. I read this before in a post. Have you tried ejecting your Satnav CD first. |
captainpegleg Member Since: 02 Nov 2015 Location: Bracknell Posts: 6 ![]() ![]() ![]() |
No I havent tried ejecting the SatNav CD, how do I do that? |
I think it's under the passenger front seat. |
Sure it's not in Off Road navigation mode? |
If so how do you get out of "off Road mode" |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
My thoughts as well ![]() |
Press the left one (marked with a compass rose symbol) of the two hardware buttons located just in front of the touchscreen and the screen changes to display a choice of 'on-road' or 'off-road' navigation. Choose 'on-road' and you're done. One thought that occurred: - if the screen is showing your position as in a field when you are actually on a road - I've seen that when using a very out of date DVD which doesn't have the most recently built roads on it's map. 2008 MY Java Black TDV8 HSE ![]() |
