Home > Technical > rrs 2006 tdv8 transmission fault traction reduced |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Transfer box failure resulting in the centre diff operating as an open diff I.e the centre diff won't lock and you would possibly struggle in challenging conditions. Could be the control module but could be the solenoid or the motor. Might just be a canbus error caused by a damaged wiring. Either way, it needs to be checked over properly. 2012 SDV6 - it's missing a couple of cylinders
Mon Feb 29 2016 6:51pm |
edviss Member Since: 29 Feb 2016 Location: london Posts: 28 |
sound like its not DIY, need to take to a local dealership or some rrs specialist i think.. either way sounds costly |
Mon Feb 29 2016 6:55pm |
