Home > Technical > rrs 2006 tdv8 transmission fault traction reduced
edviss
United Kingdom 2006 Range Rover Sport TDV8 HSE Giverney Green
hello guys , im am new in to range rover`s , always have been a bmw guy so i have bought my first rrs l320 2006 tdv8 3.6 with 71k miles on it, everything works perfectly no dashboard errors, no lights on cluster, no errors in diagnostics computer.... every time i start the car or turn the engine off "transmission fault traction reduced" comes up... any idea where to start looking for the problem?
Just had a new alternator fitted, voltage is perfect 14+
Thanks
Ed
Post #489433 Mon Feb 29 2016 6:32pm
Transfer box failure resulting in the centre diff operating as an open diff I.e the centre diff won't lock and you would possibly struggle in challenging conditions. Could be the control module but could be the solenoid or the motor. Might just be a canbus error caused by a damaged wiring. Either way, it needs to be checked over properly. 2012 SDV6 - it's missing a couple of cylinders
Post #489435 Mon Feb 29 2016 6:51pm
edviss
sound like its not DIY, need to take to a local dealership or some rrs specialist i think.. either way sounds costly
Post #489436 Mon Feb 29 2016 6:55pm
