![]() | Home > General (L494) > Product for external black plastic - removal of micro swirls |
Triumph_Dave Member Since: 11 Jul 2013 Location: Somerset Posts: 124 ![]() ![]() ![]() |
After testing several products I have found a polish that removes the micro swirls ( and scratch's ) on the external A pillars, wing mirrors and bonnet fake vents and keeps the high gloss finish of these areas..
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 ![]() ![]() |
Just ordered mine from eBay!
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Thanks - found some on Amazon, too.
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
Dave ... How much elbow grease required ?? 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
PetesRRS Member Since: 16 Jul 2015 Location: Melbourne Posts: 29 ![]() ![]() ![]() |
In Oz it is labeled as PlastX. Same product as Rx. Rx used in UK as PlastX was already registered so Meguiars could not use it and had to change the name. |
I found on the A pillars very modest pressure worked well. Initially, I tried almost zero pressure and small amounts of polish, as I was unsure of the outcome, when I found the polish was not causing any issues, I increased the pressure slightly. You will find that the polish quickly disappears, so regular topping up of a small amount works best and working a small area at a time around 5-10 cm, then removing the polish residue with a fresh cloth to check that the micro swirls have gone. On the wing mirrors I had 3-4 deeper scratches due to hedge foliage, as we have to drive down narrow West Somerset lanes and the wing mirrors catch each side. For these I had to apply a little more hand polishing pressure and regular topping up of the polish, again, I did not use large amounts, just worked the scratch area. It took longer to remove the deeper scratch, but it did work and resulted in the gloss black polished finish as per new car look. When working the deeper areas keep looking from different angles, as it polishes so well you have to catch the light across the scratch to make sure you have removed all of the scratch. In all cases I polished by hand and used new micro cloths so no external grit contamination was introduced... The external gloss black plastic trim is very susceptible to scratching.. not the best choice of material for an "off road vehicle". D4 2012 Santorini Black gone RRS 2013 Santorini HSE Black gone MY2016 RRS HSE Dynamic arrived September, but will it stay.. maybe not. |
ExpatPom Member Since: 29 Jan 2011 Location: Melbourne Posts: 90 ![]() ![]() ![]() |
Great tip, thanks for sharing! MY15.5 Fuji White, SDV8 HSE Dyn Stealth Pack
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 187 ![]() ![]() |
I'll be after some tomorrow! RRS P460e
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
Peanut butter works great........smooth, not crunchy.......I'm not joking!! |
Thanks for that Dave 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's 2013 Porsche Boxster S 3.4 2014 Audi A3 S line Quattro --------------------------------- |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 ![]() ![]() ![]() |
A much better option is poor boys black hole.
The main factor with poor boys black hole is that although its a very good product, it mainly fills the micro scratch's rather than removes them, so it does not produce a 100% permanent fix. The micro swirls can re-show after the protective wax layer has worn away. It will however show a good short term result. D4 2012 Santorini Black gone
But plast-X is a fillet based product also.
The Plast-X was the only product that I have found (so far) that will also actually polish the scratch out in the plastic, rather than just fill it and get back the factory level shine.
