![]() | Home > General (L494) > Product for external black plastic - removal of micro swirls |
jpegnall Member Since: 30 Nov 2015 Location: Surrey Posts: 76 ![]() ![]() |
I actually cannot believe how easily these scratch - less than 500 miles and 3 weeks of ownership and they are covered in scratches despite the car having had only one safety wash by the detailer. Very disappointing, the material is clearly not fit for purpose. |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 ![]() |
It's horrifically bad. When the dealer replaced my last ones they left the plastic on for me to remove. It's made in Macedonia.
How did you get them replaced, by complaining about the scratches or unrelated? |
Triumph_Dave Member Since: 11 Jul 2013 Location: Somerset Posts: 124 ![]() ![]() ![]() |
I have found that the Plast -Rx will remove most if not all of the micro scratch, the trick is to apply it with a squeaky clean cloth and use very little force, plus rub in a circular motion. If you want a quicker fix or a combination of both , then use Poor boys "black hole" which is a filler type polish and then use a very good quality wax to cover it all. It will come back like new. However, I agree the plastic trim type absolutely the worse type for the external part of the car, it is not fit for purpose. Much like the Piano Black interior trim option.. I suspect its CHEAP for LR. I have both options and even after only 1.7K miles, its been a nightmare to keep the trim looking 100%. My exterior trim came new micro scratched from the dealer. I did not notice it until the next day as it was winter and light levels poor. I wish there was a way to make LR sit up and at at least pay attention, but it seems they do not give a damm. I have had zero luck with any replies from LR. As I said previously, its annoyed me so much I am not buying another LR product, their attitude is just so bad.. D4 2012 Santorini Black gone RRS 2013 Santorini HSE Black gone MY2016 RRS HSE Dynamic arrived September, but will it stay.. maybe not. |
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 ![]() ![]() |
& lets not forget, the most expensive "optional" interior trim finish, if only they did the metal finish in an extended pack, then all would be good. RRS 2006 635d 2008 FFRR 2011 All had same finish with no problems at all... |
