![]() | Home > General > Guys Please Help Me - Reliability Question |
Lonerangerv8 Member Since: 16 Sep 2015 Location: Cheshire Posts: 83 ![]() ![]() ![]() |
See if you can get the garage to give you a warranty of some sort. If not get a quote from either warranty direct or warranty wise and see if they will go 50/50 on the cost.
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 ![]() ![]() ![]() |
You are making the correct decision getting it from a dealer. Most dealers will give a few months warranty which will buy you time until you can sort your own.
MAKRRS Member Since: 18 Feb 2016 Location: Northampton Posts: 48 ![]() ![]() |
Did they sort out the issue where 07 57 cars had the problem where after changing out the cambelts soon after didn't something crack shredding the belts and forcing a few of you to have to get new engines???
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
Yes, the oil pump casing would crack throwing out the timing and wrecking the engine.
OK if it hasn't been done on an 08 car is this almost certain to crack? The dealer may not know the answer to this that's the trouble.
So guys I'm going to see this v6 today
Think I'm putting myself off after reading so many off putting stories on here.gutted I love the car but just worrying about the engine the electrics bushes and arms have been replaced but also oil pump etc etc
Are the competitor cars more reliable ie x5 q7 vw toureg |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
I don't think you are comparing like with like by asking that question.
Yes, and no. The new design is certainly stronger, but I don't know that it's 100% infallable after another "105k", but then it can be changed again. Failures have occured outside the weak range which is why it's recommended to change it on all MYs. As long as it's changed, you don't have to worry for a long time, so in that sense, yes, the issue has an effective solution. There's no recall, because LR refuse to accept the issue publicly, however they have offered large contributions to those with applicable full service history. ![]()
Yep, and your looking for the oil pump to have been changed as above.
An oil pump from LR is circa £200+VAT (price has gone up and up ![]() ![]()
The engine is very reliable and the electrics are generally good too. Once the oil pump is done, it really shouldn't be a worry. Just remember, you hear about all the issues, but you won't see everyone else posting to say their car is running perfectly fine each day. You can always factor in a warranty too, and bear in mind, there are folk like me that are perfectly prepared to run them without one. ![]() As far as said competitor vehicles go, I can't comment personally, but from what I've read from others, they all have their issues just the same. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
If it turns out that the belt gas not been changed then use it as a bargaining tool for discount on the price and then get it done by a reputable indie then at least it will be cheaper and you will have peace of mind that it has been done.
People tend not to post on here when their cars are running as expected, otherwise it would make pretty boring reading......
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 ![]() ![]() ![]() |
Only problem I've had with mine in the year that I've had it, was it would keep coming up with a park brake fault, then it said transmission fault and that only some gears were available. if you tried to move off it would hardly move. This fault didn't happen all the time just most of the time over a period of about 3 days. Until I discovered that the high level brake light in the tailgate spoiler was dodgy and didn't always work. I fitted a new one and the faults have gone.
Here here Jim
