Home > Technical > Vibration through steering wheel and car on Acceleration |
Jylee Member Since: 28 Jan 2016 Location: Sugar land, TX Posts: 26 |
Warped front rotors. |
Thu Feb 18 2016 5:48pm |
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 |
Thanks Jaylee, forgive my lack of knowledge what's a rotor ??? MY 13 3.0 SDV6 HSE Black Edition
Thu Feb 18 2016 6:02pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
The favoured term for brake discs across the pond.
Thu Feb 18 2016 6:07pm |
Thank you will take it for another spin and see if there is any heat. The garage did service my EPB a couple of months ago. Thank you MY 13 3.0 SDV6 HSE Black Edition
Thu Feb 18 2016 6:18pm |
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 |
Check your wheel balancing
Sun Feb 21 2016 12:07am |
Thanks, bit had all wheels balanced 1st and still as bad, booked it in at the dealers, they want £95 to inspect it and should it be warranty no charge. Will see what they say, can't see it can be anything worn with only 20 k on the clock and I've never ragged it MY 13 3.0 SDV6 HSE Black Edition
Sun Feb 21 2016 2:14am |
Maybe somethings come out of line or touching something else from a pot hole or bump it's real hard to pin point without a inspection as they suggest and sometimes a road test and further investigation to provoke to problem to pin point.
Tue Feb 23 2016 2:09am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Is it still under warranty? If yes, call LR Assist. Its free so nothing to lose Visitor from fullfatrr.com
Tue Feb 23 2016 7:29am |
If its vibrating under load (acceleration) I'd check all the drive shaft and prop shaft joints; especially the centre mounting. |
Tue Feb 23 2016 9:36am |
Dropped it off Tuesday, they phoned me Wednesday at 5.pm saying they have driven it and can feel the fault, but they have no idea what it could be, they did mention that my tyres have been known to hold water, and could they keep it so they can work on it today. I was expecting some call to give me info on what they have or haven't found, but they have not, so I am still no wiser. MY 13 3.0 SDV6 HSE Black Edition
Thu Feb 25 2016 9:26pm |
Water in the Pirelli 20" tyres is the cause of this problem. I asked how often I will need to "empty my tyres"
Fri Feb 26 2016 5:51pm |
Mr Rusty Member Since: 17 Jan 2016 Location: Aberdeen Posts: 376 |
Glad you got this sorted! Weird! 2015 RRS AB SDV6, Fuji White, Ivory
Fri Feb 26 2016 8:07pm |
I was expecting the £95 charge, but they did it all through warranty. Well done Farnells of Bury. MY 13 3.0 SDV6 HSE Black Edition
Sat Feb 27 2016 9:07pm |
