Home > Technical > Fan Removal |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4950 |
Any tips on removing the engine fan ?
Sat Feb 20 2016 5:45pm |
Yes. I thought it was. |
Sat Feb 20 2016 8:02pm |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
Put the wrench on the nut (yes left hand thread) - and use a pry bar (or special fan tool) to stop the pulley spinning - sharp blow with a rubber mallet to the wrench on the nut normally works best. I just did it on my bmw and there are various you tube videos out there showing you how to do this ... |
Mon Feb 22 2016 3:29am |
Jylee Member Since: 28 Jan 2016 Location: Sugar land, TX Posts: 26 |
Al is right, you need a fan clutch hold-on wrench, and a correct size wrench. I needed a 1 1/2" wrench to remove the fan nut to change the water pump on my Dodge last week. I tried varies tools from pipe wrench to regular adjustment wrench did not work. Many trips to the store, until I found a large adjustable wrench. The nut was off in 2 minutes. I also suggest to ask a helper to hold to one wrench, while you swing a hammer on the the other wrench. |
Mon Feb 22 2016 9:58pm |
I got it off yesterday thank you.
Mon Feb 22 2016 10:03pm |
