Home > Technical > 2005 RRS shaking
looneyfitter
2005 Range Rover Sport TDV6 HSE Alaska White
2005 RRS shaking
Hi Gents any idea on what this might be? Basically when im driving the whole car shakes. It kinda wobbles so to speak almost feels like your driving over cobbles. Its really prominant at low speed and less so on motorways. Wheel bolts etc are tight and gear box feels smooth.
cheers
Post #488408 Sun Feb 21 2016 3:28pm
Camelrock
Check the tyres for damage bulges etc, have you had the wheels balanced/checked ? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #488414 Sun Feb 21 2016 4:34pm
looneyfitter
cheers just been out checked. Tyres have no buldges but could do with being replaced. front wheels have no play, however the both rears have about 3mm sideways play.. Should there be any movement in the rear top wishbone mount?
[URL=][/URL]
Post #488420 Sun Feb 21 2016 6:02pm
Camelrock
Hi mate sounds like you have warn top bushes as there shouldn't be any play. When they get bad enough the DSC starts kicking in on corners. I would jack up the car and spin the wheels to check for bulges in the tread. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #488423 Sun Feb 21 2016 6:10pm
looneyfitter
Thanks pal. Ive rotated the tyres. There not in the best condition tbh. Cant the bushes be pushed out or is it replacement arms? Pain to do or simple? Cheers
Post #488424 Sun Feb 21 2016 6:14pm
Camelrock
Can be replaced in fact did one the other day on a D3.can be a right pain as the arm has to be removed and the top inner bolt seize up and have to be cut out, not a lot of room. Also mark the outer bolt as it's an excentric cam and needs to be refitted in the same position.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #488426 Sun Feb 21 2016 6:27pm
looneyfitter
cheers pal. ill get in touch with my local indy, see what the cost to replace is..
Post #488454 Sun Feb 21 2016 10:32pm
