Home > Technical > 2005 RRS shaking |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Check the tyres for damage bulges etc, have you had the wheels balanced/checked ? 2008 G4 RRSport TDV8 current
Sun Feb 21 2016 3:34pm |
looneyfitter Member Since: 13 May 2012 Location: liverpoool Posts: 212 |
cheers just been out checked. Tyres have no buldges but could do with being replaced. front wheels have no play, however the both rears have about 3mm sideways play.. Should there be any movement in the rear top wishbone mount?
Sun Feb 21 2016 5:02pm |
Hi mate sounds like you have warn top bushes as there shouldn't be any play. When they get bad enough the DSC starts kicking in on corners. I would jack up the car and spin the wheels to check for bulges in the tread. 2008 G4 RRSport TDV8 current
Sun Feb 21 2016 5:10pm |
Thanks pal. Ive rotated the tyres. There not in the best condition tbh. Cant the bushes be pushed out or is it replacement arms? Pain to do or simple? Cheers |
Sun Feb 21 2016 5:14pm |
Can be replaced in fact did one the other day on a D3.can be a right pain as the arm has to be removed and the top inner bolt seize up and have to be cut out, not a lot of room. Also mark the outer bolt as it's an excentric cam and needs to be refitted in the same position.. 2008 G4 RRSport TDV8 current
Sun Feb 21 2016 5:27pm |
cheers pal. ill get in touch with my local indy, see what the cost to replace is.. |
Sun Feb 21 2016 9:32pm |
