![]() | Home > General > Hello everyone! RRS owner to be. Newbie |
Jylee Member Since: 28 Jan 2016 Location: Sugar land, TX Posts: 26 ![]() ![]() ![]() |
My only advice is buy one with warranty, it also help if you can do repair work. The Range Rover requires a lot more attention than average SUV/truck. |
MAKRRS Member Since: 17 Feb 2016 Location: Northampton Posts: 48 ![]() ![]() |
Hey thanks for your reply.
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 542 ![]() |
You don't say what engine derivative this one has...most likely its fitted with the 2.7 diesel.... At that age it should have had the cam belts changed by means of age..either 105,000 miles or eight years old.
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
...and consider speaking to someone like Warranty Direct to get some cover on it.
Sorry this is the 2.7 to v6 version.
Really nervous because I have waited a long time for one of these. Hope it's reliable... I don't mind spending money on it but don't wanna be spending thousands every year. Surely these 2.7v6 aren't that unreliable are they?
4X4BYFAR Member Since: 14 Feb 2016 Location: West Midlands Posts: 57 ![]() ![]() |
If you've struggled to afford the car, and £1500 for a timing belt replacement is unaffordable to you then think very wisely before purchasing. Personally I think it would be madness not to go with an approved used from a main dealer. In the next 12 months you WILL spend money on a RRS,
Thanks for the info mate
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
It's not the grey one with black wheels and black wrap on the bonnet is it?
Also try and drive more than one, if you've never drove such a car you're going to love the ride height and commanding feel. But try to drive a few just to get a feel for how they should drive/feel. There's many things to be aware of like shunting on pull off, holding gears to long, brake feel, electric hand brake noise. |
Just a correction there, Ian - 7 years. ![]()
Nearer half that at a good indy, labour rate dependant. The oil pump change is very important - it's not part of the LR service schedule, but issues have been had with the casing breaking where the cam belt tensioner is mounted, particularly in the 07/08MY range, so you would be well advised to get it done ASAP. ![]()
No. ![]() ![]()
The core engine itself is very well proven with failure rates inline with others. TDV6 turbos fair better than the TDV8 and are not too bad.
Very good, but very important to maintain it. At 60k, I would look to have the box flushed now. ![]()
Yes. Complex, so issues can and will arise, but they're generally well designed cars. You will always hear horror stories, but we are here to help and can sometimes save you a fortune. ![]()
Extremely. ![]()
Only a second or two. The compressor will run a little longer to pressurise the gallery. I suggest you spend as much time as possible searching on here and DISCO3 since it's impossible to go through everything. I note you are considering a remap from your other thread - I recommend you take the opportunity to blank the EGRs (07MY onwards requires a software patch that can be done with the remap) which are a common failure point. ![]() Good luck and enjoy. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Thanks so much for your response.
Suspension has 3 options, access (lowest) normal (middle) off road (highest). They are preset heights and you have no option to adjust them.
Great cars, however you MUST buy a car with warranty, plus a full service history, Main dealer preferable.
