![]() | Home > Technical > Flat battery |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 ![]() ![]() ![]() |
I would remove the positive terminal and charge it on the car.
I think the 2 options stated refer to using the unit as 1) a boost starter, for a battery struggling to start the car or 2) as a conventional battery charger, to charge the battery over a period of time.
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 210 ![]() ![]() ![]() |
As the guys have said above, you have got a battery charger with 'boost start' function. To charge the battery, disconnect the leads from the battery and connect the red lead to the positive (+) terminal (greater in diameter than the negative terminal), and the black lead to the negative (-) battery terminal. Plug in the charger and set it to charge on a low trickle charge for 24 hours.
Leave the battery connected else I think you ought to have the Battery Monitoring System reset, and thus be sure also to put the negative on a ground point not the terminal. If you are using a reconditioning mode then the battery should be taken out of the car but otherwise it can stay as it is. |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
Thank you guys,
Good afternoon fellas,
sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961 ![]() ![]() ![]() |
Hi mate. Ring Dan at Duckworth (site sponsor). He will give good price and correct one |
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 ![]() ![]() ![]() |
Guys
