Home > Maintenance & Modifications > Determining air compressor type
Guyzer73
Oman 2006 Range Rover Sport Supercharged Vesuvius Orange
Hi everybody,
Just a quick question...
Is there an easy way to determine which air compressor I have installed for the EAS? I know initially I had an Hitachi. Then I presume in 2009 when it was replaced, another Hitachi was installed.
However after that this was replaced in July 2010 under warranty by a 3rd compressor... Is there a way to tell if this is:
1 An Hitachi
2 An early AMK or
3 The new AMK?
I've got an IID Tool also if that helps.
Thanks in advance.
Oh and if you're wondering it's because I want to get a service kit as the compressor is humming and running more than it should be...
Thanks again
Guy 2006 RRS S/C CONSTANTLY under modification...
1994 RRC 4.2l not LSE sadly gone but not forgotten
LR Defender 300Tdi - affectionately know as "The Black Beast"
Post #486617 Fri Feb 05 2016 5:25am
Lost for Words
With the IID, select ECU Flashing > Suspension and choose the option to indentify the firmware. It's possible for the AMK to be fitted but the firmware not updated though, in which case you'd need to check under the cover AFAIK. Firmware is the same for either AMK version but it would be the original type available then, which is what I'd expect to have been fitted. Thumbs Up Visiting from DISCO3.CO.UK
Post #486637 Fri Feb 05 2016 10:42am
Guyzer73
LfW Bow down
Thanks for that it took a whole minute to do this and it comes back as Hitachi Thumbs Up
Post #486795 Sat Feb 06 2016 7:10pm
Lost for Words
Just bear in mind then that you may want to do a physical check then just in case the software hasn't been updated correctly. Thumbs Up Visiting from DISCO3.CO.UK
Post #486829 Sun Feb 07 2016 9:45am
Tizzard
Can I ask what make and grade of oil are you guys using in the tdv8s as will be doing mine soon.
Cheers Thumbs Up
Post #486953 Mon Feb 08 2016 9:20pm
The Duke
France
Well that's been an interesting few weeks...
I have replaced 2 compressors for the suspension the 1st one OE from Land Rover dealership was kindly fitted by one of the Disco 3 guys, thanks Kris, however it came back with a fault on the exhaust so he refitted the old one as I was heading off to France. Kris returned the new compressor as faulty and they sent a new replacement which I had fitted yesterday but didn't have the tool to do the update. So I took it to DSL in Worksworth Derbyshire and paid the princely sum of £54 for them to update the software and this has also come back with a fault on the exhaust.
Any ideas!!!
Post #487612 Tue Feb 16 2016 10:45am
