![]() | Home > Maintenance & Modifications > Determining air compressor type |
With the IID, select ECU Flashing > Suspension and choose the option to indentify the firmware. It's possible for the AMK to be fitted but the firmware not updated though, in which case you'd need to check under the cover AFAIK. Firmware is the same for either AMK version but it would be the original type available then, which is what I'd expect to have been fitted. |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
LfW |
Just bear in mind then that you may want to do a physical check then just in case the software hasn't been updated correctly. |
Tizzard Member Since: 30 Nov 2015 Location: Nottingham Posts: 64 ![]() ![]() |
Can I ask what make and grade of oil are you guys using in the tdv8s as will be doing mine soon.
The Duke Member Since: 12 Aug 2015 Location: Brittany Posts: 10 ![]() ![]() |
Well that's been an interesting few weeks...
