Home > General > knocking suspension
stevehill
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
knocking suspension
Sad
bought our range rover sport hse new in march.
the vehicle has been back to the dealer 4 times
with a knocking comming from underneath the car.
over certain bumps and if steering wheel is turned from side to side
noise can clearly be heard
land rover uk told them it was from the dynamic anti roll bars
and would not be prepared to replace the system as the noise was a characteristic of the dynamic pack
yeah right!
can anyone help
Post #48660 Fri Aug 11 2006 6:30pm
Firstly Steve welcome. The dealer is talking rubbish I have no knocking. You might want to have a word with the service manager and direct him to this forum - I think name and shame tactics might come into play unless things are sorted quickly. Others will post shortly because I'm sure this problem has appeared before and results gained. 2005 Zambezi TDV6 - Gone but not forgotten
Post #48661 Fri Aug 11 2006 6:34pm
Welcome mate
I didn't have any knocking noise coming from under my RRS but the suspension did drop on one Side they sorted that out
 RRS TDV6 Gone but still around
Post #48663 Fri Aug 11 2006 6:41pm
stevehill
yes i have done all of that to no avail
they had three vehicles on the ramp only mine made this noise
Land rover uk sent two technicle staff armed with gadgets and gismos
took the fuse out to the dynamic responce sysystem which stopped the noise.
they then went on to say the dynamic responce system is a floating valve and could be taken off the vehicle to cure it
what was the point in having in the first place
Post #48664 Fri Aug 11 2006 6:47pm
Tell them if they take it out then you want your 2.5k back as well see what they say then! RRS TDV6 Gone but still around
Post #48665 Fri Aug 11 2006 6:51pm
They should replace the parts through warranty - they have pinpointed the fault. This is not a characteristic of the RRS. As I said there are others more qualified than me that will point you in the right direction. You also might want to look at our sister site disco3.co.uk where the members are more technically aware! As the D3 & RRS are basically the same car the same questions and problem apply. 2005 Zambezi TDV6 - Gone but not forgotten
Post #48666 Fri Aug 11 2006 6:52pm
stevehill
they said i would have to cough up 585.00 plus three hours labour
which Lancaster Reading said may or may not cure the problem
it is totally ruining my enjoyment of the vehicle
the dealer said their hands were tied by Landrover uk
Post #48667 Fri Aug 11 2006 7:02pm
You can always take it to another dealer - warranty work is covered by all dealers! A call to LR customer services will also help! 2005 Zambezi TDV6 - Gone but not forgotten
Post #48668 Fri Aug 11 2006 7:05pm
MAW
Definately call Cust svc's - that s the only way I got results to my complaints - even then not as quick as I would have liked....
Post #48675 Fri Aug 11 2006 9:59pm
Bobby
You're definitely being shortchanged, stevehill.
This is a warranty problem and must not cost you anything! Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #48688 Sat Aug 12 2006 12:35am
