Home > In Car Electronics > Key not working to start engine
jaipal2004
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Orkney Grey
managed to break the little silver thing on my 2006 RRS keys that is used for the key ring. Purchased a new key case and transferred all the innards over to the new one.
The buttons work to open and close doors, key goes into ignition no problem but when I attempt to start it - nothing!
My 'non-tampered' key works fine thankfully.
Do I need to get mine re-coded or have I damaged something? I'd assume, if it was the latter then nothing would work?
THanks for your help!
Post #486067 Sat Jan 30 2016 12:07am
TubaPlayer
i'm not an expert on RRS keys but i know with my Jag the remote buttons were programmed separately to the ignition chip, so basically if you have damaged the key it could in theory operate the remote buttons but not the ignition. 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #486071 Sat Jan 30 2016 1:24am
anthony-apl
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
It sounds like you have damaged the transponder chip on the circuit board. It's black long and square and is soldered onto the board at the thinner end nearest the blade. Any decent locksmith (like me!!) will be able to test the key for you and see if the chip is reading. The remote will still work as this is a separate part but coded at the same time 16 model year yulong white autobiography
Bentley continental GTC
2011 VW Transporter T5 Kombi 140BHP with sport line kit for work
15 model year black RRS HSE gone
11MY Fuji White 3.0 TDV6 HSE
Ivory premium leather
Ebony contrast stitching
Extended leather pack
Anigra Wood now gone
08MY Range Rover Sport TDV6 GONE
Post #486134 Sat Jan 30 2016 5:31pm
jaipal2004
thanks guys Smile
Can the transponder be replaced / fixed or should I source a new blank key?
Would the key-encoding service guys at Timpsons be able to do a fresh one / repair old one? I've had them cut me a key and encode a transponder on another car in the past (Subaru).
Ta
Post #486236 Sun Jan 31 2016 11:31pm
anthony-apl
Forget timpsons mate different job on a Scooby. I could probably be able to clone your working key and put a new chip in the damaged one but I'm based in Manchester and I would need the car at my shop. 16 model year yulong white autobiography
Post #486237 Sun Jan 31 2016 11:43pm
jaipal2004
Thanks mate .... You need the keys or the car too? Could've posted the keys possibly.
Must be somebody locally that can do it?!
Ta
Post #486240 Mon Feb 01 2016 12:07am
anthony-apl
Yes I would need the car. You need a decent auto locksmith that knows what there doing. 16 model year yulong white autobiography
Post #486247 Mon Feb 01 2016 8:25am
