Home > General (L494) > Gearbox won't select gear (L494 MY16) |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
Does the gear indicator on the dash flash? This has happened to me once, possibly twice, a while back when the stop/start kicked in at the same time I lifted off the foot brake to drive off. |
Fri Jan 29 2016 6:37pm |
Stuff Member Since: 29 Jan 2016 Location: In between cradle and grave Posts: 11 |
No warnings on the dash, no audible warnings, and no R or D lights on the gearstick once the problem occurs, but the P light shows when the P button is pushed and the pawl must engage because the car won't roll after that. |
Fri Jan 29 2016 6:46pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Could be the brake light switch (which does a whole lot more than just turn on the brake lights) failing or out of adjustment.
Fri Jan 29 2016 9:09pm |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 |
Last time ours was at the dealers the wife was offered a rrs demo to use but they couldn't bring the car around to the front of the dealership for her as it was stuck in gear and unable to move . |
Sat Jan 30 2016 5:34pm |
