![]() | Home > General > Automatic Headlight Levelling |
I didn't think our vehicles had auto levelling headlights - I thought this was effectively achieved by the air suspension keeping the vehicle level.
The xenon lights do self level in cooperation with the suspension system. The xenons have a safety feature to prevent glare to oncoming drivers; if the headlight can't be sure where it's pointing, it will lower the beam. The only fix appears to be a new headlight unit - that seems to have fixed the same issue with my MY08.
Chilly07 Member Since: 25 Dec 2015 Location: Central Coast, NSW Posts: 24 ![]() ![]() |
Which adjuster? I notice that your lights are the non-adaptive ones so probably different to the AFS ones on mine. 2012 SDV6 - it's missing a couple of cylinders
Inside the headlight. The white plastic ball on the end of the threads was no longer connected to the headlight. |
Ah, I see. Glad it was an easy fix - nothing so simple for me, sadly. 2012 SDV6 - it's missing a couple of cylinders
What is wrong with yours?
Mine are active. The horizontal steering system (makes the beam steer left and right) was going awry. Needed a new headlight unit. Luckily sourced for an excellent price from a forum member. 2012 SDV6 - it's missing a couple of cylinders
