Home > General > Automatic Headlight Levelling
Chilly07
Australia
TDV8 RRS2008 with Auto Levelling Headlights.
Drivers side facing downwards. What controls this? Cannot see any driver mechanism in the headlight?
How do I test or what should I be looking at?
Non Adaptive headlights.
Thanks,
Chilly
Post #485578 Sun Jan 24 2016 12:07am
garrycol
Australia
I didn't think our vehicles had auto levelling headlights - I thought this was effectively achieved by the air suspension keeping the vehicle level.
But then I only have a poverty pack model and not sure what extra gear the luxo barge models have.
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #485579 Sun Jan 24 2016 12:12am
The xenon lights do self level in cooperation with the suspension system. The xenons have a safety feature to prevent glare to oncoming drivers; if the headlight can't be sure where it's pointing, it will lower the beam. The only fix appears to be a new headlight unit - that seems to have fixed the same issue with my MY08.
Interestingly, the lights will also "raise" the beam slightly at speed in order to increase the distance that the beam is projected. 2012 SDV6 - it's missing a couple of cylinders
Post #485624 Sun Jan 24 2016 12:51pm
Chilly07
Australia
Thanks for the replies.
Well, pulled the Headlight out and had a good look....noticed the adjuster was adrift.
All back together and lights adjusted. Now to check alignment when dark.
Thanks.
Chilly
Post #485693 Mon Jan 25 2016 2:43am
Which adjuster? I notice that your lights are the non-adaptive ones so probably different to the AFS ones on mine. 2012 SDV6 - it's missing a couple of cylinders
Post #485697 Mon Jan 25 2016 8:03am
Chilly07
Australia
Inside the headlight. The white plastic ball on the end of the threads was no longer connected to the headlight.
Post #485782 Tue Jan 26 2016 10:14am
Ah, I see. Glad it was an easy fix - nothing so simple for me, sadly. 2012 SDV6 - it's missing a couple of cylinders
Post #485827 Tue Jan 26 2016 10:11pm
Chilly07
Australia
What is wrong with yours?
I too was pleased a simple fix....not fancy paying lots of dollars to replace....
Post #485859 Wed Jan 27 2016 11:07am
Mine are active. The horizontal steering system (makes the beam steer left and right) was going awry. Needed a new headlight unit. Luckily sourced for an excellent price from a forum member. 2012 SDV6 - it's missing a couple of cylinders
Post #485908 Wed Jan 27 2016 9:22pm
