![]() | Home > Technical > Heater Motor |
Lazy relay (probably). Try swapping it with another (engine bay fusebox) and see if it cures it. |
chi Member Since: 15 May 2010 Location: hampshire Posts: 49 ![]() ![]() |
Hi Lost for Words
There won't be a spare, if that's what you mean, but, you could swap temporarily with, for instance, the headlamp washer one. Then you'll be able to see if it is indeed the issue. |
HI again Lost for Words.
Many thanks to Lost for Words.
Deuchars Member Since: 26 Jul 2015 Location: North Wales Posts: 38 ![]() ![]() ![]() |
Can you tell me where the relay is, and which one it is. I have a similar problem thats causing me some grief.... cheers 2008 Supercharged Stornaway Grey, 22inch black Stormers
On the back of the engine bay fusebox lid there's a diagram with symbols that should direct you to it. |
