Home > General (L494) > 16MY Rear Wiper Stopped Working
Autobiography
I have had issues on my own and a loan car with the new rear wiper on 16MY cars. On the loan car, the wiper got stuck at the intermittent position and wouldn't move. On my own car yesterday, the wiper just stopped working completely. The jet still worked but the wiper didn't move from its parked position.
Anybody else had issues?
Post #481831 Mon Dec 07 2015 6:19am
RRSman
Sounds like wintwr mode is on...have a look in to settings using the steering wheel and untick winter mode.
Post #481836 Mon Dec 07 2015 7:45am
Dave777
First time I used my MY16 wipers they kept stopping in a strange place and I thought they were broken. Winter mode was on in the dash info screen! Turned off and all fine. MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys.
Post #481840 Mon Dec 07 2015 8:13am
Autobiography
Winter mode only affects the front wipers I believe.
This was also in 12 degrees and a few minutes after it worked perfectly!
Post #481844 Mon Dec 07 2015 9:08am
Dave777
Good news. The temperature doesn't affect it. It is a mode you activate yourself so you can lift the wipers off the screen to clear snow. MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys.
Post #481847 Mon Dec 07 2015 9:50am
Tim in Scotland
I haven't had to do it yet on my RRS2 but on both Evoques that i have owned you have to set the wipers to the winter setting BEFORE you even attempt to lift them off the glass to clean/ change the rubbers. If you don't you will at least damage the paintwork on the the edge of the bonnet of an Evoque at worst you will also damage the wiper arm by bending it too much trying to get enough clearance from the glass to change the rubbers! Another Great Design feature from Land Rover....... also if you are putting the wipers into the winter park position then switch off the wiper auto on function for them too. If you don't and the rubbers freeze to the glass, the second that you press the starter button the wiper will try to wipe the ice off the screen. Switching back to manual operation prevents damage to the rubbers when frozen and the winter park position means that the blades are parked on top of the lower part of the screen heater elements and will get defrosted as the screen defrosts. I have also found that Halfords sells quite a good "night before" screen spray that you spray over the screen and the chemical will prevent the blades and the screen from freezing, however if the temperature rises and there is drizzle or rain then the spray gets washed off the screen rendering it useless should the temperatures then plummet. So set your wipers back to Manual on before a frosty night to avoid wearing out the rubbers when they grate across the screen in the morning because you forgot to switch it off! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #481891 Mon Dec 07 2015 8:23pm
Triumph_Dave
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
Autobiography... very interesting .. On my own car yesterday morning I went to use the read wiper and wash, it worked for 3-4 squirts of the washer/wipe then the rear wiper stopped completely.. The washer jet still worked but no wiper. Ironically this happened on its way into the dealer where it was going to be looked at for floppy leather and intermittent DAB radio.. So the issue of the wiper has been also given to the dealer to fix. Also of note.. once at the dealer, I turned the ignition off and then back on and it all started working again??.
I haven't heard back from the dealer about the fault, but when I do I will let you know what they found ( if anything )..
Dave D4 2012 Santorini Black gone
RRS 2013 Santorini HSE Black gone
MY2016 RRS HSE Dynamic arrived September, but will it stay.. maybe not.
Post #482517 Tue Dec 15 2015 4:09pm
Triumph_Dave
Re: 16MY Rear Wiper Stopped Working
Well the car has been with Taunton Land Rover for over a week and they say they can not replicate the fault of the intermittent rear wiper failure.
Not happy, this is yet another nail in the coffin with Land Rover..
Post #483112 Tue Dec 22 2015 2:22pm
mattmars
I have experienced the same problem on my 16MY. I have to turn the car off and back on again to get the rear wiper to work. Did the dealer find a solution to the problem? I haven't taken my car in to them yet.
Post #485743 Mon Jan 25 2016 5:42pm
Triumph_Dave
Hi , its happened three times now. My dealer can not find the fault and says there is no fault code recorded!. They say there is nothing else they can do unless more owners with the same fault start reporting it to Land Rover. !. D4 2012 Santorini Black gone
Post #485753 Mon Jan 25 2016 6:52pm
wilf
Happened to me twice now. Each time it restarts after an engine stop and restart.
I'll mention it to my service manager. See what he says. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #485771 Mon Jan 25 2016 9:08pm
Mark_N
At least you have the rear camera wash jet... Sad Mark
SVR in Estoril Blue Thumbs Up
Post #485843 Wed Jan 27 2016 7:43am
Triumph_Dave
That's true Very Happy but then again I also had, DAB radio blanking out, interior burning plastic smell, floppy leather on seats and front parking sensors switching off as "add on" extras... kind of get one fault and another 3 (non related) faults free... D4 2012 Santorini Black gone
Post #485849 Wed Jan 27 2016 8:44am
