Home > Technical > Electric window sticking!
Ovey
Hi all, I have an issue with the drivers window. When I press the switch to open it, it moves 1-2mm but no further; it moves back up to seal again ok too.
The other three windows are all fine and I have performed the window reset in accordance with the manual. Any ideas?
I'm guessing it's not the fuse as the window will move a little bit each way, and the relay is shared by all windows so this is probably fine too.
(MY10 RRS 3.0TDV6)
Thanks! Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Previous: Discovery 3 2.7 TDV6 HSE in Zambezi Silver
Post #484985 Sun Jan 17 2016 11:47am
Ovey
Aha! Fixed!!
Someone on the Facebook group came up trumps for me. It was the anti-pinch mechanism that needed resetting as the window must have been frozen shut when I last tried to open it. I disconnect the battery -ve terminal for 20 seconds then reconnected. Reset the windows and I now have 4 working windows!!
Thought I'd post the fix here in case anyone else gets it! Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Post #484991 Sun Jan 17 2016 12:16pm
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
How did you do the reset?
Post #485078 Mon Jan 18 2016 7:22am
Ovey
Close the windows with the switch, release the switch and then pull the switch up for about 3 seconds and release. You need to do this on all four windows, from the drivers door position. Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Post #485122 Mon Jan 18 2016 3:32pm
Seepee3o
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Santorini Black
Ovey wrote:
Aha! Fixed!!
That worked for me too today thanks. Noticed whilst driving that drivers door window went down 10mm and stopped - could raise it to fully closed though all through the drivers door switch. Reading this thread I remembered a couple of days ago I tried to lower the window but it was frozen so never thought much about it - the reset procedure fixed it straight away Very Happy
Post #609611 Sat Feb 06 2021 12:51pm
