![]() | Home > Technical > Electric window sticking! |
Ovey Member Since: 21 Jan 2015 Location: Portsmouth area Posts: 80 ![]() ![]() ![]() |
Aha! Fixed!!
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
Close the windows with the switch, release the switch and then pull the switch up for about 3 seconds and release. You need to do this on all four windows, from the drivers door position. Current: Range Rover Sport 3.0 TDV6 HSE in Stornoway Grey
Seepee3o Member Since: 05 Dec 2020 Location: Hogsthorpe Posts: 12 ![]() ![]() ![]() |
That worked for me too today thanks. Noticed whilst driving that drivers door window went down 10mm and stopped - could raise it to fully closed though all through the drivers door switch. Reading this thread I remembered a couple of days ago I tried to lower the window but it was frozen so never thought much about it - the reset procedure fixed it straight away ![]() |
