Home > Maintenance & Modifications > Whilst the body is off
htc
United Kingdom 2010 Range Rover Sport TDV8 HSE Buckingham Blue
Hello from a newbie.
My RRS has an oil leak from the rear ARB and will probably have a body off to replace the unit (under warranty thankfully).
So I was thinking of getting those annoying hard to get to small jobs done while the body is off.
Any thoughts on what I should get done?
Also, could you pse point me to the anti theft device for the keyless cars.
Many thanks!
Post #484836 Fri Jan 15 2016 3:19pm
shakeapaw
I believe the job can be done by undoing the rear bolts only and jacking the body up 6" to allow access, so I would check with the dealer to see if they are doing it this way 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #484849 Fri Jan 15 2016 4:34pm
Disco_Mikey
The above is correct. Body only needs raised a little
If they do lift the body, consider replacing the ARC pipes front and rear, as well as brake pipes
Post #484850 Fri Jan 15 2016 4:57pm
