![]() | Home > Technical > 3 pages of fault codes ! |
smiler148 Member Since: 06 Sep 2015 Location: forfar Posts: 28 ![]() ![]() ![]() |
Hi there.
bhattman13 Member Since: 30 Sep 2014 Location: London Posts: 5 ![]() ![]() ![]() |
Hi, thanks for the response. I have only had the car back from the last repair for 2 weeks and I know they cleared all the fault codes then. Most of the codes were for reduced Traction, HDC fault, Cruise control unavailable, etc etc. I have read other posts which suggest the brake switch so I'll try to get that fixed first. |
Yes the brake switch is a common fault. Im sure someone will be along soon to give some more input.
Yes, had 4-wheel alignment and two new front tyres as part of the wishbone fix. |
Sounds like they aren't too familiar at dealing with fault codes. Brake switch is a possibility, and check (replace) the brake bulbs as a matter of course (ensure they're decent quality ones). Also check the basics - battery and alternator voltages. |
Thanks for the advice. Local Indy, recommended and they did a pretty good job on the other stuff that has already gone wrong. Not sure about the steering angle sensor though, I'll check the paperwork.
