Home > Technical > Pela Oil Change- the wonder of it!
jasons
2012 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Did two oil changes yesterday and today and quite frankly I'm amazed....
The RRS took less than 15 minutes to do- and most of that was trying to remove an over torqued oil filter cover.
The wife's Mini took longer yesterday but only because the oil wasn't as hot. (Well, I'm not going to practice on my car am I....)
Seriously I'm in awe of how easy it made it.
I thoroughly recommend it from a speed and more importantly mess aspect, not a drop spilt on the ground, no messing around underneath the car etc.
The Pela cost £35 off eBay and arguably the most value for money item in my garage. 2012 RRS HSE. Firenze Red.
Post #484284 Fri Jan 08 2016 1:14pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Got a link ???
How much did you drain out. Personally I like to drain all 6 ltrs, are you using that small pipe left hand side of engine bay to suck the oil out ???
Post #484287 Fri Jan 08 2016 2:17pm
jasons
This was the one-
http://www.ebay.co.uk/itm/281657544262
It's the 6 litre one and it filled to the top ( and then some), 5.75l back in.
Literally less than 5 mins to drain through the tube. 2012 RRS HSE. Firenze Red.
Post #484292 Fri Jan 08 2016 3:56pm
ABSport
The one in the link is not £35 as your stating. It's £136.99 Embarassed
Post #484293 Fri Jan 08 2016 4:21pm
jasons
My bad, £1.89 over the £35 I said it was... 2012 RRS HSE. Firenze Red.
Post #484294 Fri Jan 08 2016 4:28pm
TheWojtek
Check your credit card statement/paypal transactions, please:
This is http://www.ebay.co.uk/itm/281657544262 as seen on a desktop.
EDIT: It seems, though, the price has hiked within last 2-3 days... Previous transactions were actually for the smaller price. I wonder if this is a sellers mistake: http://offer.ebay.co.uk/ws/eBayISAPI.dll?V...7675.l2564 Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #484330 Sat Jan 09 2016 12:18am
tanloverluke
check this one out:
http://www.ebay.co.uk/itm/Brand-New-Pela-o...1657544262
and this one:
http://www.ebay.co.uk/itm/Pela-6000-Spheri...1657544262 Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
DONE: Meduza front bumper, AB rear bumper, AB tailpipes, calipers repainted, rear upper tailgate upgrade, side steps, AB front grille, AB side vents, rear LED lights, clear side repeaters, integrated daytime running lights, LED headlights.
TO DO: color code sills and pillars.
Post #484337 Sat Jan 09 2016 9:35am
jimbg
Great bits of kit.
I have used the original one http://www.amazon.co.uk/Pela-Oil-Extractor...B002EPSF7E for my boats for the last 20 years. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #484361 Sat Jan 09 2016 2:22pm
idrabble
Australia
Could one of these (or similar) be used to extract all gearbox oil and therefore allow a home based mega flush to be carried out?
Thoughts anyone?
Post #487845 Thu Feb 18 2016 2:24am
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
There are a couple of good threads on the Disco Forum where folk have used a pump up weed killer spray to flush their gearboxes.
I recently used a pump up sprayer when I changed my diff oils and transfer box oil. It really does make an awkward job easy!
Jim
Post #487859 Thu Feb 18 2016 8:32am
idrabble
Australia
I used my automatic brake fluid bleeder http://www.gunson.co.uk/item.aspx?item=1818 to change my diff oils, just took the output hose off the end cap that goes on the brake fluid reservoir
Post #487862 Thu Feb 18 2016 9:11am
flack
I have two of these pumps, a 7ltr and a 14 ltr one both Sealey, they are a god send when changing the oil, They get every last drop out if you place the pipe correctly, and like what has already been said they make no mess.
Flack Thumbs Up
Post #488115 Fri Feb 19 2016 6:01pm
