![]() | Home > Maintenance & Modifications > 2015 Range Rover Sport Shark Fin antenna. |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
Can you tell us what part numbers/cables we need? and more importantly how you did it |
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 737 ![]() ![]() ![]() |
I am particularly interested in an idiots' guide to removing the headliner. Regards etc.,
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
To remove the rear section ( to do it properly ) without creasing it, Remove both rear boot side wall panels these are the carpet side panels they are only clipped in. Once removed you then remove the rear upper panels covering seat belts. Then Unclip the edge of the headlining to expose the shark fin installed. Unplug the cables all cars are different you may have the single cable or 2. Then remove the 2 bolts securing the shark fin then it can be pulled away from the car roof.
indeed it does |
![]() ![]() Wojtek --- WAS: 2006 RRS Supercharged IS: 2010 RRS TDV8 HSE |
rajranjit Member Since: 09 Dec 2017 Location: Devon Posts: 2 ![]() ![]() |
Hello can you please let me know the part number and how much it cost you. I live in Newton Abbot. Where did you purchased the part Many thanks |
I replaced my RRS1 one with the Shark fin one from the RRS2, twice in fact because the Sat Nav side of it failed both times, they were bought new from dealer not second hand. Whether I was just unlucky and they were faulty units and just failed or they are not really compatible with the RRS1 electronics I don't know, they did last a few months each time . Fitted a new original fitment one and has been perfect ever since. The part number of the RRS2 one I used is LR059756 if you want it.
Thank you very much. It’s great help. Let you know how I get on. |
