Home > General > check brake pads warning
benj193
Hi Guys, i have a my06 sport and the brake pad warning popped up yesterday.
Anybody have any idea roughly how long i can use the car for without replacing them? - this isnt to be silly or tight, but i dont think i can get any pads today as it is new years day Sad
cheers
Post #483716 Fri Jan 01 2016 1:22pm
DrRob
You should be fine if the light has only just come on. Just be gentle. Visitor from fullfatrr.com
Post #483717 Fri Jan 01 2016 1:31pm
Ianm
United Kingdom 2012 Range Rover Sport SDV6 HSE Stornoway Grey
Must be something in the air (or rather rain) my brake pad warning lights also just come on - but not constantly, must be just on the cusp of needing changing - and I've 600 miles to do before I can get them checked Embarassed
Post #483723 Fri Jan 01 2016 4:38pm
DrRob
I had front discs and pads done recently for £250 all in. Main stealer wanted over £500 Censored Visitor from fullfatrr.com
Post #483729 Fri Jan 01 2016 6:13pm
Ianm
Crazy money! - I took my defender in for its first (6k mile) service, it took 1.5 hours (including being washed) and cost just over £500!! - bearing in mind it was basically brand new so other than oil & a filter (which can't cost that much) how on earth do you get to £500?? (I accept ones got to make a profit & there are overheads to be paid for)
Main dealers, don't you just love them......(& yes in did 'phone several dealers & they all charge the same)
Post #483733 Fri Jan 01 2016 6:36pm
R444SPT
Never good to check the bill, and see the oil cost, that's probably half the total cost of the service, what ever happened to a 5 litre can for £5 from halfords....
Post #483768 Sat Jan 02 2016 9:01am
Disco_Mikey
Its maybe good enough for a Fiesta, but it's not what you would be putting in a £10k engine Thumbs Up
Post #483769 Sat Jan 02 2016 9:03am
R444SPT
Get that completely, although we are talking about a defender engine here, not the latest much more modern technology available on newer designed engines.m
Of course we could drift into manufacturer / oil company relationships,many the comparable price for other OEM oils.
A minefiled. Big Cry Whistle
Post #483770 Sat Jan 02 2016 9:20am
Disco_Mikey
You would be surprised just how technically advanced the current Defender engine is Thumbs Up
I do agree though, it's pure profiteering from the dealers. When I was working in the dealership 10 years ago, the oil (Castrol) was £13.95 + VAT per litre! You can buy 4 litres of Magnatec for £20
Post #483773 Sat Jan 02 2016 9:46am
Tyrefitter
When I had my Subaru Impreza sti I used millers oil & it was & £80 a gallon & I changed it every 5000 miles.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #483775 Sat Jan 02 2016 10:56am
benj193
finally got them replaced, turns out the sensor was cracked... new sensor as well. not a bad price either, all in all £105
very happy i can drive again now Mr. Green
Post #483822 Sat Jan 02 2016 8:08pm
Si-W85
I too have just replaced my pads and wear sensor on the front as the tears were done not too long ago, anyway the check brake pad warning light is still on but goes off when I press the pedal but comes straight back on, anybody any ideas as to why it would do this? Thanks
Post #484400 Sun Jan 10 2016 12:25am
benj193
sounds like the sensor again... its quite a long cable so could be split somewhere?
i would go back to the garage who changed them and ask for a free check over. - most garages do free checks, and if anything is found they tell you
Post #484406 Sun Jan 10 2016 10:41am
Si-W85
I changed them myself I have checked continuity across the new sensor and all is good, I'm thinking I may just do away with it and short out the connector as its driving me mad. I read somewhere that it can take a few trips out before it goes out but I have drove it loads and it's still doing it, also would have thought it either worked or it didn't :/
Post #484407 Sun Jan 10 2016 10:51am
Bodsy
Site Sponsor
No, it either works or doesn't, no need for multiple trips out. Sounds like you need to check the other sensor, or it's not fully plugged in, or there's a crack (usually where it is angled and goes onto the pad) Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #484408 Sun Jan 10 2016 11:13am
