![]() | Home > General > 2010 front bumper removal - instructions? |
WEERAB Member Since: 09 Jan 2014 Location: CANNOCK Posts: 9 ![]() ![]() ![]() |
Just remove headlights and front grille and you will see all the screws required then before you remove all have a look at the inner splash guards and check if there are any of the screws holding them on pull it back far enough to remove headlight washer pipes and front spot plugs then it should slide out |
