Home > General > 2010 front bumper removal - instructions?
J2D
Has anyone got any links to good videos on how to remove a 2010 front bumper on a RRS?
Thanks in advance
John
Post #483435 Mon Dec 28 2015 10:48pm
WEERAB
Just remove headlights and front grille and you will see all the screws required then before you remove all have a look at the inner splash guards and check if there are any of the screws holding them on pull it back far enough to remove headlight washer pipes and front spot plugs then it should slide out
Post #483451 Tue Dec 29 2015 11:00am
