Home > Technical > parking sensors stopped working |
vam17hel Member Since: 19 Mar 2015 Location: North Yorkshire Posts: 30 |
Any ideas in which direction to look other that l/r dealer plug in (bend me over a barrel and lots of lub first haha).Driving home the other night no problem reversed into drive and got the 3 second tone and flashing switch,now its all the time.The sound is from unit in the boot can't hear any clicks from sensor but it would appear system shut down although unlike last time when front sensor went no message up on dash screen, odd that .It had 4 new front sensor this year ??.I don't this thing likes crimbo time cost me £800 on EGR valves this time last year.BAR HUMBUG. |
Sun Dec 27 2015 11:59am |
just to add i've just been out in car and the 3 sec sound and flashing switch light happen as soon as ignition is turned on to position 2 even in park |
Sun Dec 27 2015 6:09pm |
URX Member Since: 09 Feb 2009 Location: Edinburgh Posts: 194 |
Wiring loom in front bumper did exactly this on mine.
Sun Dec 27 2015 6:34pm |
ok mate will check that in morning looks like bumper off !! again |
Sun Dec 27 2015 6:41pm |
Finally got time to do checks,i'm getting two fault codes one saying no supply two front sensor circuit and the other the same but to rear, checked both plugs and 12 volt at each if unpluged from bumper looms but drops to 0.4 volts when connected
Tue Jan 12 2016 6:07pm |
update 2:- The problem is instant as soon as i put in ign key and turn to position 2 ign on and not running the 3 second beep and flashing light start ,now i see most posts are saying on selecting reverse this happens but not in my case and as i said fault codes are saying no power to front or rear sensor circuit so they will not tick will they as not powered up could this be the control module has died is it common for them to go .most electrically un-relible i have ever owned any help to restore my faith most welcolme |
Fri Jan 15 2016 2:38pm |
update 3:- having spent all day and both bumpers off doing all the multimeter checks going,cleaning out crap and sealing plugs i think i'm nearly there system is now sort of trying in 3 sec beep gone but no sounders re coupled my icarsoft reader and did a live data check and now have supply back but 1 rear sensor has died and one front (new but cheap import crap from guess where folks mistake) has gone already salt on roads i suspecting but who at R/R designed something electrical to be located in direct firing line of the rear wheels .SPOT ON that one.watch this space |
Sun Jan 17 2016 1:40pm |
Problems all sorted for future reference DO NOT buy cheap sensors that come from china although they are listed in the UK |
Thu Mar 03 2016 9:48am |
