![]() | Home > General > OBD port protection |
Darbs Member Since: 03 Dec 2015 Location: Cheshire Posts: 96 ![]() ![]() |
Trying to upload some pictures but being a bit thick. 😬 can only get them to appear in my gallery !!!
Interesting |
Came from Protectavan, 160. Well worth it for peace of mind !! |
Might be a silly question but why does the OBD2 port need protection?? 07MY RRS TDV6
labulette Member Since: 12 Oct 2015 Location: grenoble Posts: 13 ![]() ![]() ![]() |
Maybe because an OBD access, with a "good" program you could initialize a new key..... |
Check out YouTube, rrs taken in under two minutes without a sound !!! |
Wasn't that a L494 which do have a security issue which allows easy access to the car when it is locked. If thieves have the skill to break into the security system of the car then I am sure they will be able to remove the OBD2 lock in a short time.
fjanssen Member Since: 07 Jul 2012 Location: Dilsen Posts: 18 ![]() ![]() ![]() |
Make the original OBD as a dummy.. And on a hidden place the new OBD port😉 |
The OBD port is merely a spur of the CANBUS; they need only go underneath and probe it elsewhere to achieve the same. Visiting from DISCO3.CO.UK
Any car with keyless entry is at risk. All these measures do is slow them down or make them pick an easier target. |
Or put a simple hidden switch between the wires to the fuel pump😉 |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1194 ![]() ![]() ![]() |
quick question - where is the OBD2 port on the L494?
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
This was an issue when I had my ST. A few people bought various OBD protectors, some went to Screwfix and bought virtually the same stuff for £8 |
