Home > Maintenance & Modifications > Nasty odour |
Could you be smelling the exhaust from another vehicle being drawn in to the car? Petrol engines make that smell if they are not running right.
Wed Dec 09 2015 5:25pm |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Hi paddi, pretty sure it's not other car fumes I did also think that myself but few times smelling it I have not been near any traffic, had a Indy full service about 2 months ago APPARENTLY they changed all filters, as for air con, I put both temp dials on cold put vents on face settings and turn fan up full so should be ice cold, am I correct.
Wed Dec 09 2015 7:17pm |
Ned Member Since: 25 Jul 2015 Location: London Posts: 100 |
Check ya battery. |
Wed Dec 09 2015 9:06pm |
Yes I'm sure Ned's advice to check battery for anything nasty like bulging or low electrolyte makes sense in case the alternator is cooking it makes sense ; but please wear goggles and gloves as I've heard too many horror stories about exploding batteries and lost eyesight!!
Wed Dec 09 2015 10:20pm |
Done a check on battery and alternator and battery seems good, alternator Amber light and red, Amber normal, red over charging, will it be suspected bad alternator causing overcharge, air con nice and cold this morning but will get it tested anyway, |
Thu Dec 10 2015 8:54am |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 |
Have a suspicion that what you're smelling is the catalytic converter. I think the rotten egg whiff is only produced by petrol engines though? Air movement around the car can be quite random, especially if you're stationary or in slow moving traffic, so takes a certain set of criteria for the 'zorst gases to be drawn into the fresh air vents. That's one theory anyway |
Thu Dec 10 2015 9:42am |
Don't think alternator is overcharging, just tested partners car and reading is exact same so suspect the tester I purchased from eBay is not reading correct, onboard sat nav screen diagnostics reads 12.5v+ just ignition, and 14v+ with engine running. |
Fri Dec 11 2015 8:34am |
Gilly my van had a rotten egg smell have you checked the electrolite in the battery cells presuming you have that type of battery one of my battery cells collapsed this gives off the egg smell.
Fri Dec 11 2015 8:55am |
Hi ned, it's derv, will have a look and check, had bonnet up yesterday and done a long visual and had good smell round battery and engine bay, couldn't smell anything, just strange that smell is only maybe once every journey and only smells for max 10/15 seconds.
Fri Dec 11 2015 9:03am |
