![]() | Home > Technical > Turbo whistle tdv6 |
Deefur Member Since: 09 Dec 2015 Location: Dunfermline Posts: 19 ![]() ![]() ![]() |
Hi guys, new member here so be gentle!
Welcome. |
The exhaust isn't the standard "down facing" rear pipes, they are around 3" oval shaped, could that be the cause? |
The tailpipes couldn't cause that alone - it's only what lurks in front of them that would make any difference. |
Is there an easy way to tell if it's been decatted? And I mean a really easy way, my technical knowledge is less than zero!!! |
If you take a look undeneath, you can see if the standard cat is there (it's also possible to cut it open and weld instead of replacing). |
Thanks for that mate, I'll have a look once it stops pouring with rain! |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
Th turbo may just be more vocal than others, it does happen
Is that an easy check for a garage to carry out Disco_mikey? |
Depends how good the garage is |
I'll get it to an independent LR garage shortly methinks, I'm not paying main dealer prices! |
I'll be in Dunfermline tomorrow |
Don't suppose I could be cheeky and ask for a free opinion on it while you're in the area? nothing intrusive just to listen to it, I'd come to wherever you'll be in dunf. |
Send me over your address |
Massive thank you to disco_mikey for popping down today, it seems the turbo is to blame for the noise, I've only had the car a week so it was a phone call to the garage that sold me it and credit to them it's going in on Monday for diagnostics and possible new turbo. |
