Home > In Car Electronics > Surround Cameras Retro |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 |
Hi Guys,
Tue Dec 08 2015 12:55pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 |
I have just had a look at L/R parts list and apart from the five cameras (even the reverse cam is different) you would appear to need the camera control module, Tailgate Harness, Front Bumper Harness, Possibly Engine Bay and Main Dash Harness. There is something like Twenty Main Harnesses listed depending on Engine, Sound System and various other options fitted so how on earth you would begin to decide which one you needed I would not have a clue.
Tue Dec 08 2015 6:18pm |
Hi Col,
Tue Dec 08 2015 6:30pm |
I would imagine if you take out a short subscription to Topix you should be able to find all the relevant wiring diagrams and download them.
Tue Dec 08 2015 6:44pm |
One thing I did think of was that you can get a universal kit where you can select which cameras come on when then feed it into where the reverse camera is but could not find where the reverse camera is connected or the signal type |
Tue Dec 08 2015 6:54pm |
I do know on the actual Reverse Camera the Fixed one has a coax cable with a Fakra connector and two terminal pins, on the Surround Camera there is the coax cable and four terminal pins. Unfortunately I would not know where they actually go to from the camera.
Tue Dec 08 2015 7:13pm |
I guess its anologe. Will try to test when I can. |
Tue Dec 08 2015 7:17pm |
Hi
Tue Dec 08 2015 7:30pm |
Tue Dec 08 2015 7:33pm |
lol if I can work out how they are wired and if it can then be enabled, might be knocking on your dor lol |
Tue Dec 08 2015 7:54pm |
The my10/11 vehicles has analogue cameras. They changed to digital on 2012 onwards.
Tue Dec 08 2015 8:23pm |
Rear Camera
Tue Dec 08 2015 8:45pm |
Great Stuff!!!
Wed Dec 09 2015 7:12am |
I would say so, that reverse camera is a different connector to the standalone reverse camera (which is analogue) Bodsys Brake Bible
Wed Dec 09 2015 8:27am |
