![]() | Home > In Car Electronics > Surround Cameras Retro |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
Hi Guys,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5029 ![]() ![]() ![]() |
I have just had a look at L/R parts list and apart from the five cameras (even the reverse cam is different) you would appear to need the camera control module, Tailgate Harness, Front Bumper Harness, Possibly Engine Bay and Main Dash Harness. There is something like Twenty Main Harnesses listed depending on Engine, Sound System and various other options fitted so how on earth you would begin to decide which one you needed I would not have a clue.
Hi Col,
I would imagine if you take out a short subscription to Topix you should be able to find all the relevant wiring diagrams and download them.
One thing I did think of was that you can get a universal kit where you can select which cameras come on when then feed it into where the reverse camera is but could not find where the reverse camera is connected or the signal type |
I do know on the actual Reverse Camera the Fixed one has a coax cable with a Fakra connector and two terminal pins, on the Surround Camera there is the coax cable and four terminal pins. Unfortunately I would not know where they actually go to from the camera.
I guess its anologe. Will try to test when I can. |
Hi
lol if I can work out how they are wired and if it can then be enabled, might be knocking on your dor lol |
The my10/11 vehicles has analogue cameras. They changed to digital on 2012 onwards.
Rear Camera
Great Stuff!!!
I would say so, that reverse camera is a different connector to the standalone reverse camera (which is analogue) Bodsys Brake Bible
