Home > Technical > Dummies guide to IID suspension adjustment needed |
2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sun Dec 06 2015 9:05pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
I did do a custom height setting on my IID a year or so ago. Can't remember the details though but sure the info is in the user guide. I went for a +25 setting as a trial for an off road day I went on. Gave a 75mm lift at off road height.
Sun Dec 06 2015 11:08pm |
Scratch that. The new menu structure means you'd adjust using the height menu and then use the save my settings option in the save/restore menu.
Sun Dec 06 2015 11:23pm |
Thanks RRSTDV8.
Mon Dec 07 2015 11:33am |
Not able to give any info on min/max settings as I haven't played with it enough. It might be a trial and error, especially for the access height as that will, when too low, send it to off road height automatically. I'm fairly sure I read in the manual (or on here) that, because each vehicle has its own calibration, each vehicle will have slightly different max and min heights that it can go to. 2012 SDV6 - it's missing a couple of cylinders
Mon Dec 07 2015 11:04pm |
Yes i think it is prob slightly different, for each car has its own calibration,. All im really after is a rough idea of safe lowering figure so access is still available and a safe increase figure for offroad. I can then use these as a base and tweak from there!
Tue Dec 08 2015 2:09pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
IIRC, most people can get a 50mm lift out of it, but as RRSTDV8 says, it does vary between vehicles. Visiting from DISCO3.CO.UK
Tue Dec 08 2015 2:28pm |
The possible issue with increasing offcroad base height too far is that you run out of movement earlier. That is, if the vehicle is running at +50 for the standard height and you then select off road mode, you get 100mm over the stock height. Great, but that only leaves you with a small emergency lift available in the event that you bottom out. Also, you don't give the suspension much scope to articulate. I think the car can provide up to 125mm of suspension rise over stock "normal" height.
Tue Dec 08 2015 2:50pm |
One issue that's important to remember, is that once you get really high, the risk of pulling a driveshaft out on full lock becomes very real (as well as generally increased stress on the CV joints) - it's strongly recommended to keep the wheels as straight as possible should you ever find yourself in super-extended mode! Visiting from DISCO3.CO.UK
Tue Dec 08 2015 3:00pm |
Thanks Lost for Words and RRSTDV8. Think I will just play and see how I get on! I have to say and extra 50mm over standard offroad height would definitely come in handy at times
Tue Dec 08 2015 7:13pm |
