![]() | Home > Technical > 2005 SC Auxillary heater light |
Hallelujah! There's your answer..... On 2007 models, that light is changed for a normal Lights sign. You have the 2008.5 software which gives you the clock on the dash (or at least it will once you've done a hardware reset). Older systems couldn't remove that red light, but it can now be removed if you have it reprogrammed. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
gangnam007 Member Since: 17 May 2015 Location: london Posts: 49 ![]() ![]() ![]() |
how much would it cost to recode it? |
Will drop you a PM. |
