Home > General > Light control module |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
There is the AFS module on the A-Pillar for the adaptive front lights |
Mon Dec 07 2015 9:21pm |
jimmy2loads Member Since: 07 Mar 2015 Location: chester Posts: 7 |
Cheers Mikey, I forgot to add, my motor is a 2005 rr sport, where exactly is it on the a pillar, underneath by the throttle pedal area, or windscreen area? |
Mon Dec 07 2015 10:14pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
The AFS module is on the A-pillar behind the glove box. You need to remove the fusebox to get it out. The module above the throttle pedal is the air suspension module (along with the dynamic response module (when fitted)). 2012 SDV6 - it's missing a couple of cylinders
Mon Dec 07 2015 10:56pm |
