Home > Faults & Fixes > Brake caliper issue
Williamsboy
Wales 2005 Range Rover Sport TDV6 HSE Rimini Red
Brake caliper issue
Hi guys just a heads up, on Monday whilst driving home from work I was cut up on a round about in Caerphilly south wales. This forced me to take another route home , and I am glad to say how lucky I feel that I did. As I had to take the incorrect exit off the roundabout in question I decided to pop into the local petrol station to check my tyre pressures. Whilst doing this I noticed my N/S/F brake caliper was not in contact with all of my brake disc. The bolt at the upper location on my caliper was missing and had allowed the caliper to slide off the disc. I have had to buy a new fitting kit as the slider which receives the bolt had been cro:ssed threaded by the previous person who had worked in the location. I have had a new gearbox fitted this year and am not sure if they had to remove the brake calipers to carry out the gearbox replacement or it was when the garage fitted new brake pads before I purchased the rrs last December. So basically if you have had any work done recently on your brakes please check the torque on the caliper retaining bolts. I took pictures which I will try and add to my gallery for viewing.
All the best
Mike Thumbs Up
Post #481515 Wed Dec 02 2015 10:10pm
Williamsboy
Brake caliper issue photo
Here is the photo of the missing bolt
Post #481516 Wed Dec 02 2015 10:42pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
You were lucky you spotted that, I have seen worn pads come out in the past and they can make some mess. Wink Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #481518 Thu Dec 03 2015 12:36am
Lost for Words
Shocked
Another good reason for DIY maintainence. The peace of mind is worth it's weight in gold. Wink Visiting from DISCO3.CO.UK
Post #481524 Thu Dec 03 2015 9:31am
gogsy1956
So,,,, no other indication that something was wrong,,,, rattles or strange noises??,,, certainly been lucky you checked your tyres! 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #481529 Thu Dec 03 2015 11:11am
Williamsboy
No strange noises or loss of braking noticed to be honest. the only thing i noticed was a couple of days earlier my brake pad wear warning flashed up on the info screen for a few seconds and then disappeared, it did not indicate a problem as it went straight off and did not come back on.
Mike
Post #481534 Thu Dec 03 2015 12:51pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Your'e a lucky boy my friend, good job you spotted it ! no telling what could of happened Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #481539 Thu Dec 03 2015 4:04pm
Lost for Words
It's a somewhat less considered blessing to have the modern ABS systems that we do for such potential instances too. Thumbs Up Visiting from DISCO3.CO.UK
Post #481543 Thu Dec 03 2015 4:27pm
Bodsy
Site Sponsor
Well spotted Thumbs Up could have had disastrous consequences. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #481565 Thu Dec 03 2015 7:28pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Thank god for Bodsy's Brake Bible Bow down
I'd recommend all to print off and use if doing DIY.
Post #481568 Thu Dec 03 2015 7:36pm
Finndog
hi you you still in the update business?
Post #481574 Thu Dec 03 2015 8:42pm
Bodsy
Site Sponsor
Yes Thumbs Up
Have replied to your reply pm. Thumbs Up Bodsys Brake Bible
See it HERE
Post #481596 Thu Dec 03 2015 10:34pm
Williamsboy
Cheers everyone for your replies, I am lucky that I spotted the issue when I did. What worries me though, was on the Sunday evening I picked my daughter and her friend up from a show in Cardiff bay and drove them to Swansea for a birthday get together with friends . It was pouring down all day and crappy drizzle all evening, the M4 was horrible to drive on.
Kind regards
Mike Thumbs Up
PS I have my copy of Bodsy's brake bible in my garage, where it has been for quite some time.
I think we all owe him a few beers. Next time your in sunny south wales give us a heads up for a few beers..
Post #481600 Thu Dec 03 2015 11:05pm
dux
Sorry to revive this old thread, but do you happen to know what the correct torque settings on our caliper bolts should be?
Mine is a 2012 RRS S/C (5.0L) with Brembo High Perf brake calipers.
Does 275Nm (202 lb ft) sound about right?
Thanks in advance.
Post #504043 Tue Aug 30 2016 3:14am
Williamsboy
I would message Bodsy or Discomike, i am sure they would know the correct torque settings for the bolts you are after.
I just tightened my bolts up until i was happy that they would not come adrift again, but that torque seems high for the caliper bolts, or do you mean the carrier which the caliper bolt onto. The carrier bolts onto the front hub and then caliper fits onto that.
Mike
Post #504055 Tue Aug 30 2016 8:25am
