Home > General (L494) > Whirring noise.... Help please .
Andyowen
Hi guys . My new HSE with 2000 miles has a whirring/whining noise when cold only that sounds like it's coming from the engine bay in front of the passenger seat . Goes off when the car Is fully warmed up but I'm sure it wasn't there last week. Any ideas ? It stops when the engine stops via the auto stop/ start .
Post #481357 Tue Dec 01 2015 12:05pm
foxtrotzulu
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
Probably a stupid answer, but I spent a few days tracking down a whirring noise in the cabin which turned out to be the fridge unit.
Post #481363 Tue Dec 01 2015 12:49pm
mikeyross
Mine (on 2000 miles) has a sort of whistle/whine when cold that disappears after a while running and has been doing it pretty much from day one. I haven't been too worried, but am open to extreme alarm and demands for help from the dealer ... Laughing
Post #481365 Tue Dec 01 2015 1:44pm
Could be the viscous fan.
Post #481366 Tue Dec 01 2015 1:51pm
Maidenmania
I've got the same noise in the same place except it's there all the time along with what sounds like knackered wheel bearing noise when driving my can has 3500 miles. Booked into dealers on the 18th 2008 Factory HST- Sold
Arrived 2016 HSE carpathian grey
Post #481371 Tue Dec 01 2015 2:51pm
Elfer04
South Korea
My SDV8 has a similar noise, but from the driver side from what I can figure. I'll be interested to hear your dealer's diagnosis if you could share it later. Thanks.
Post #481530 Thu Dec 03 2015 11:14am
Tim in Scotland
If the outside temperature is below 5c then it could be the FBH that helps warm the engine faster to reduce emissions, I'm not sure if RRS2 has this, but it is often something that causes queries from those new to an RRS1, especially when they also see whitish smoke coming from the front of the car (it's the FBH exhaust!) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #481541 Thu Dec 03 2015 4:11pm
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
If you are using heated/cooling seats then you will hear whirring noise as they are based on fans rather then heating elements.
Post #481610 Fri Dec 04 2015 7:16am
gregfreer
England 2010 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
Did anyone get a diagnosis on this noise? My work colleague has a similar noise in his.
Post #492070 Tue Mar 29 2016 1:00pm
Cantona
Could it be the wife Very Happy
Post #492088 Tue Mar 29 2016 3:14pm
gregfreer
Laughing Laughing Laughing
The strife is just white noise nowadays.................
Post #492096 Tue Mar 29 2016 3:55pm
IRBails
Australia
I was just looking at this topic and thought it would be good if all members had what version of the RRS they owned in their Sig. As there are many variants it is hard to reply with specific info. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #492148 Tue Mar 29 2016 9:04pm
Stuff
I have this. It's not the FBH nor the viscous fan. It sounds like a noisy bearing on a small fan inside the climate system - a slight constant speed whistle. It comes when the car is cold and climate is set to auto. I can render it inaudible by turning the fan speed down to the lowest level - one notch above off. The noise ceases when the car has warmed up.
My guess is that it's a cheap component somewhere. I've decided to treat is as one of those things to put up with. I know, you shouldn't have to on a car at this price, but ... but ... I really can't be running to and from the dealer for this, and it might wear off as the car gets a few more kms under its belt.
Post #492152 Tue Mar 29 2016 9:22pm
IRBails
Australia
Not knowing the posters engine, I did not give any useful info in my previous post, but if it is a turbo you often hear turbo whine when the motor is cold . M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #492154 Tue Mar 29 2016 9:25pm
Stuff
I don't think it's that. The noise does not vary as you might expect with turbo speed. It's more like the constant noise you used to get from a knackered fan on an old PC. Another thing I wondered was whether a gate in the ventilation system is set closed or partially open when cold so that the air whistles through a gap, and the gate changes position when the car has warmed up, causing the whistle to stop.
It's not a seat ventilation fan nor a cubby box fridge - my car has neither.
Mine is an SDV8 with about 2,600 km on the clock.
Post #492156 Tue Mar 29 2016 9:34pm
