Home > General (L494) > Whirring noise.... Help please . |
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 |
Probably a stupid answer, but I spent a few days tracking down a whirring noise in the cabin which turned out to be the fridge unit. |
Tue Dec 01 2015 12:49pm |
mikeyross Member Since: 11 Aug 2015 Location: Brighton Posts: 41 |
Mine (on 2000 miles) has a sort of whistle/whine when cold that disappears after a while running and has been doing it pretty much from day one. I haven't been too worried, but am open to extreme alarm and demands for help from the dealer ... |
Tue Dec 01 2015 1:44pm |
Could be the viscous fan. |
Tue Dec 01 2015 1:51pm |
Maidenmania Member Since: 13 Feb 2014 Location: Yorkshire Posts: 138 |
I've got the same noise in the same place except it's there all the time along with what sounds like knackered wheel bearing noise when driving my can has 3500 miles. Booked into dealers on the 18th 2008 Factory HST- Sold
Tue Dec 01 2015 2:51pm |
Elfer04 Member Since: 08 Apr 2015 Location: Seoul Posts: 4 |
My SDV8 has a similar noise, but from the driver side from what I can figure. I'll be interested to hear your dealer's diagnosis if you could share it later. Thanks. |
Thu Dec 03 2015 11:14am |
If the outside temperature is below 5c then it could be the FBH that helps warm the engine faster to reduce emissions, I'm not sure if RRS2 has this, but it is often something that causes queries from those new to an RRS1, especially when they also see whitish smoke coming from the front of the car (it's the FBH exhaust!) 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Dec 03 2015 4:11pm |
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 |
If you are using heated/cooling seats then you will hear whirring noise as they are based on fans rather then heating elements. |
Fri Dec 04 2015 7:16am |
gregfreer Member Since: 26 May 2014 Location: Breaston Posts: 9 |
Did anyone get a diagnosis on this noise? My work colleague has a similar noise in his. |
Tue Mar 29 2016 1:00pm |
Cantona Member Since: 27 Oct 2015 Location: Cheshire Posts: 518 |
Could it be the wife |
Tue Mar 29 2016 3:14pm |
Tue Mar 29 2016 3:55pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 865 |
I was just looking at this topic and thought it would be good if all members had what version of the RRS they owned in their Sig. As there are many variants it is hard to reply with specific info. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Mar 29 2016 9:04pm |
Stuff Member Since: 29 Jan 2016 Location: In between cradle and grave Posts: 11 |
I have this. It's not the FBH nor the viscous fan. It sounds like a noisy bearing on a small fan inside the climate system - a slight constant speed whistle. It comes when the car is cold and climate is set to auto. I can render it inaudible by turning the fan speed down to the lowest level - one notch above off. The noise ceases when the car has warmed up.
Tue Mar 29 2016 9:22pm |
Not knowing the posters engine, I did not give any useful info in my previous post, but if it is a turbo you often hear turbo whine when the motor is cold . M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue Mar 29 2016 9:25pm |
I don't think it's that. The noise does not vary as you might expect with turbo speed. It's more like the constant noise you used to get from a knackered fan on an old PC. Another thing I wondered was whether a gate in the ventilation system is set closed or partially open when cold so that the air whistles through a gap, and the gate changes position when the car has warmed up, causing the whistle to stop.
Tue Mar 29 2016 9:34pm |
