![]() | Home > General (L494) > First service...when? |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Your engine oil level isn't rising by any chance?
KenD Member Since: 27 Feb 2007 Location: Essex Posts: 34 ![]() ![]() ![]() |
Have a similar problem, only the service warning is showing on my Incontrol Remote app. but not in the vehicle.
GUM97 Member Since: 01 Jun 2013 Location: North West Posts: 2 ![]() ![]() |
There's currently a field action by LR, Q519. There's a software issue, meaning the DPF is failing regeneration, contaminating the oil quality and bringing the service light on prematurely. Take it into the dealer, who'll reconfigure the PCM as required, and if necessary replace the throttle body (only certain batches require this step), and then if your service light has come on, they'll carry out an oil and filter change under warranty.
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439 ![]() ![]() |
Thanks for this Gum97 landroverpete can you please confirm the above? Thanks |
Thanks for your help GUM97. Mine was one of the batch you mentioned, Had the throttle body replaced and a sensor changed 3 weeks ago, but they made no mention of oil or filter change. This now has me worried. Should I contact them and quiey it ? I must admit that the only service warning I'm getting is on my Incontrol Control App.and not on the RRS display. |
DRDlLL, did they drain your oil and replace the filter? |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
Currently got the same issue with my L405.
Dave777 Member Since: 15 Feb 2015 Location: Sussex Posts: 485 ![]() ![]() |
What does contaminated, overfilled oil do to the engine and emissions/economy/performance? |
Well I was told by the LR assist technician that if i drove it any longer I would have |
JasM, was the warning on your L405 display in cab, as mine (RRS) is only showing on my Incontrol Remote App. The only warning I had prior to Recall was the DPF warning, had no service required warning on RRS display.
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 ![]() ![]() ![]() |
The InControl warnings don't appear to be reset. Mime is still showing a TPMS warning. |
This is very concerning indeed! My car needs to go back to LRPR to have this sorted asap! |
Yes the message was showing on the TFT screen/ Cluster, my car doesn't have Incontrol fitted, was an optional extra the time. I would get them to check the oil level, only way of knowing whether it requires an oil change. 2014 L405 SDV8 RR Autobiography ![]() 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone ![]() 2007 RRS TDV6 HSE - Zermatt Silver - Gone |
Thanks JasM, I think I'll do what you suggested and get them to check oil level and put my mind at rest. |
