Home > General (L494) > First service...when?
Page 1 of 4 1234>
RRSman
My RRS has only done 6500 miles and is now 7 months old. It's asking for the first service but how can that br right? LRPR currently have my car and the service advisor was also surprised to see the service light on so quickly as usually its' 12 months or 12k miles.
When was your first service? Thanks
Post #480946 Thu Nov 26 2015 6:50pm
wilf
Your engine oil level isn't rising by any chance?
If so there could be a DPF issue needs fixing, and pronto. I would usually expect to see a DPF warning first, but not sure if RR software echoes Jaguar or not. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #481049 Fri Nov 27 2015 8:37pm
KenD
England 2007 Range Rover Sport TDV6 SE Zambezi Silver
Have a similar problem, only the service warning is showing on my Incontrol Remote app. but not in the vehicle.
RRS is 9 months old and done 9,800 miles. Not due for a service till 2nd March 2016 or sooner if I do enough milage according to my Dealer. Spoken to Incontrol they couldn't help and told me to contact Land Rover who have tried to fix the problem to no avail. They (LR) have now told me to contact my Dealer which I have. They (Dealer) say they dont know what's causing it but it's safe to drive and they will look into the problem.
Has anybody got any any suggestions other than deleting the Incontrol App?
Post #481081 Sat Nov 28 2015 11:28am
GUM97
There's currently a field action by LR, Q519. There's a software issue, meaning the DPF is failing regeneration, contaminating the oil quality and bringing the service light on prematurely. Take it into the dealer, who'll reconfigure the PCM as required, and if necessary replace the throttle body (only certain batches require this step), and then if your service light has come on, they'll carry out an oil and filter change under warranty.
Hope this helps Thumbs Up
Post #481115 Sat Nov 28 2015 4:58pm
RRSman
Thanks for this Gum97 landroverpete can you please confirm the above? Thanks
Post #481134 Sat Nov 28 2015 8:58pm
KenD
Thanks for your help GUM97. Mine was one of the batch you mentioned, Had the throttle body replaced and a sensor changed 3 weeks ago, but they made no mention of oil or filter change. This now has me worried. Should I contact them and quiey it ? I must admit that the only service warning I'm getting is on my Incontrol Control App.and not on the RRS display.
Post #481156 Sun Nov 29 2015 9:43am
KenD
DRDlLL, did they drain your oil and replace the filter?
Post #481220 Sun Nov 29 2015 8:21pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Currently got the same issue with my L405.
Service required message showing on my L405 despite last service carried out in May. Anyway I called out LR assist who carried out diagnostic checks and no faults was showing.
However thanks to this thread I then asked him to check the oil level, he realised straight away their was a problem, the engine oil has an excess amount of contaminated oil present and would require an oil & filter change.
It's now been booked in to my local dealer to get it sorted out. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #481332 Mon Nov 30 2015 11:50pm
Dave777
What does contaminated, overfilled oil do to the engine and emissions/economy/performance? Shocked MY16 3.0 SDV6 Autobiography in Aleutian silver, stealth pack and toys.
Post #481345 Tue Dec 01 2015 8:17am
JasM
Well I was told by the LR assist technician that if i drove it any longer I would have Censored the engine!
Glad I got it checked out as I have a 600 mile trip on the weekend and I was going to take the L405! Shocked
So if anyone gets a premature service requires message don't ignore it, get the oil level checked out. 2014 L405 SDV8 RR Autobiography Cool
Post #481346 Tue Dec 01 2015 8:40am
KenD
JasM, was the warning on your L405 display in cab, as mine (RRS) is only showing on my Incontrol Remote App. The only warning I had prior to Recall was the DPF warning, had no service required warning on RRS display.
Spoken the Grange Motors Service who carried out the throttle body, sensor and software change, they told me that as it was only the software permaturely bringing the DPF warning on, the oil would be OK.
Land Rover and Grange haven't any idea as to why the Incontrol App is still showing a warning, or any idea as to how to fix it.
Post #481358 Tue Dec 01 2015 12:19pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
The InControl warnings don't appear to be reset. Mime is still showing a TPMS warning.
Post #481367 Tue Dec 01 2015 1:51pm
RRSman
This is very concerning indeed! My car needs to go back to LRPR to have this sorted asap!
Post #481368 Tue Dec 01 2015 2:00pm
JasM
Yes the message was showing on the TFT screen/ Cluster, my car doesn't have Incontrol fitted, was an optional extra the time.
I would get them to check the oil level, only way of knowing whether it requires an oil change. 2014 L405 SDV8 RR Autobiography Cool
Post #481383 Tue Dec 01 2015 6:01pm
KenD
Thanks JasM, I think I'll do what you suggested and get them to check oil level and put my mind at rest.
Post #481385 Tue Dec 01 2015 6:30pm
Page 1 of 4 1234>
