Home > Technical > supercharged misfire
my 1st sport
United Kingdom 2013 Range Rover Sport Supercharged Orkney Grey
Hi
does anybody else have a misfire on 06 RRS supercharged when its cold .when its warm it runs great.
Post #457292 Thu Mar 26 2015 11:13pm
Unclebuck
United Kingdom 2005 Range Rover Sport Supercharged Bonatti Grey
Supercharged misfire when cold
Hi, did you sort out your misfire ?
Post #480776 Mon Nov 23 2015 9:13pm
my 1st sport
Hi
no just run it like it is doesn't seem to make any difference still runs nice when driving and no hesitation when accelerating.
Post #480782 Mon Nov 23 2015 10:02pm
Unclebuck
Ok, just that mine has started misfiring on start up when cold , it causes the car to judder in either reverse or drive , I have to take it out of gear, Rev it up , put it back in gear and it seems to be then ok , misfire gone no more judder , until you leave it ,say overnight and misfires back !
Post #480785 Mon Nov 23 2015 10:25pm
my 1st sport
that's a bit different to mine it will go along without any shuddering on tick over. suppose you got to start with getting it plugged into the computer.not losing any coolant are you ?
Post #480789 Mon Nov 23 2015 11:11pm
Unclebuck
No loss of coolant , why do you ask ?
Post #480791 Mon Nov 23 2015 11:42pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
No codes or check engine light ? How many miles ? Were plugs ever changed ? Try cleaning mass air sensor ...
Post #480792 Tue Nov 24 2015 7:21am
smiler148
hi there.
Worth changing the spark plugs first if they have not been changed for a while.
Failing that get your codes scanned it is most likely is a coilpack starting to fail. Should show a code stating low resistance on coilpack or similar.
Post #480846 Wed Nov 25 2015 1:07am
Unclebuck
New plugs fitted about 3 weeks ago ! I have a Gap IID tool and nothing is showing up even after turning off the engine whist I feel the misfire is happening ! I will reiterate the symptoms: first thing in the morning start the car put into reverse and whilst reversing the car seems to be juddering as though it's not firing on all cylinders , so I put it into neutral or park , Rev the car which seems to clear the 'misfire' it then seems to reverse fine and drive spot on until it's left again for say 8 hours and it occurs again !
Post #480894 Wed Nov 25 2015 10:31pm
alpaca
Did that start right after the new plugs ? I'd use contact grease spray on coil boots and reseat them all again. If that doesn't make any difference maybe a bad plug was installed , or bad gap, or not torqued properly. Who did the plugs and which ones were used ? If it was a shop , I ask them to check the work again.
Post #480898 Wed Nov 25 2015 11:26pm
johnunleashed
2007 Range Rover Sport Supercharged HST Java Black
Hi if you have a good code reader you can go into the data stream and look up the misfire count , it should show all 8 cylinders , check the counts on each cylinder they should be around 0 , if one is showing high number's that's where to start looking , if the count goes above a certain percentage then it will put a DTC code but if its lower than the set percent it wont , it could be a possible clogged injector , there is a land rover bulletin about the injectors clogging up and to use BG 44K Fuel System Cleaner before replacing the injectors , hope that may help 2007 SUPERCHARGED HST
Post #481008 Fri Nov 27 2015 12:30pm
johnunleashed
found the Bulletin
Reference SSM46917
Models LR3
LR4
New Range Rover
Range Rover Sport
Title 4.2/4.4/5.0 Gasoline Fuel Additive For Clogged Fuel Injectors
Category Engine
Last modified 31-Jan-2011 00:00:00
Symptom 499000 Basic Engine
Content Issue:
Fuel injectors clogged leading to potential problems such as poor running, poor fuel economy, excessive exhaust emissions, hard starting, rough idle, misfires and engine detonation.
Cause:
Poor fuel quality or fuel contaminants restricting the fuel injector flow rate.
Action:
Land Rover engineering now approve the use of BG 44K Power Enhancer Cleaner (which is sold in an 11oz/325ml can or bottle) on 4.2/4.4 AJV8 and 5.0 AJ133 Gasoline engine derivatives.
The above mentioned additive should be used in the first instance in an attempt to cure a suspected �clogged� injector (misfire DTC maybe stored) rather than unnecessary replacement.
NOTE: Land Rover recommend only using the above product a maximum of twice between each 15K service. 2007 SUPERCHARGED HST
Post #481009 Fri Nov 27 2015 12:34pm
Unclebuck
Thanks for that I will have a go !
Post #481010 Fri Nov 27 2015 1:12pm
