![]() | Home > Technical > supercharged misfire |
Unclebuck Member Since: 04 Dec 2014 Location: South Yorkshire Posts: 51 ![]() ![]() ![]() |
Hi, did you sort out your misfire ? |
my 1st sport Member Since: 11 Nov 2014 Location: west midlands Posts: 22 ![]() ![]() ![]() |
Hi
Ok, just that mine has started misfiring on start up when cold , it causes the car to judder in either reverse or drive , I have to take it out of gear, Rev it up , put it back in gear and it seems to be then ok , misfire gone no more judder , until you leave it ,say overnight and misfires back ! |
that's a bit different to mine it will go along without any shuddering on tick over. suppose you got to start with getting it plugged into the computer.not losing any coolant are you ? |
No loss of coolant , why do you ask ? |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 ![]() ![]() ![]() |
No codes or check engine light ? How many miles ? Were plugs ever changed ? Try cleaning mass air sensor ... |
smiler148 Member Since: 06 Sep 2015 Location: forfar Posts: 28 ![]() ![]() ![]() |
hi there.
New plugs fitted about 3 weeks ago ! I have a Gap IID tool and nothing is showing up even after turning off the engine whist I feel the misfire is happening ! I will reiterate the symptoms: first thing in the morning start the car put into reverse and whilst reversing the car seems to be juddering as though it's not firing on all cylinders , so I put it into neutral or park , Rev the car which seems to clear the 'misfire' it then seems to reverse fine and drive spot on until it's left again for say 8 hours and it occurs again ! |
Did that start right after the new plugs ? I'd use contact grease spray on coil boots and reseat them all again. If that doesn't make any difference maybe a bad plug was installed , or bad gap, or not torqued properly. Who did the plugs and which ones were used ? If it was a shop , I ask them to check the work again. |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 ![]() ![]() |
Hi if you have a good code reader you can go into the data stream and look up the misfire count , it should show all 8 cylinders , check the counts on each cylinder they should be around 0 , if one is showing high number's that's where to start looking , if the count goes above a certain percentage then it will put a DTC code but if its lower than the set percent it wont , it could be a possible clogged injector , there is a land rover bulletin about the injectors clogging up and to use BG 44K Fuel System Cleaner before replacing the injectors , hope that may help 2007 SUPERCHARGED HST |
found the Bulletin
Thanks for that I will have a go ! |
