Home > Faults & Fixes > LIMP MODE
jonesy_boys
United Kingdom 2006 Range Rover Sport TDV6 HSE Firenze Red
LIMP MODE
Hi, iv recently changed the turbo and both egr valves on my range rover sport tdv6 2.7 2006. after being replaced after acceleration the vehicle goes into limp mode?? does anyone have any ideas, please help.
Post #480764 Mon Nov 23 2015 5:58pm
Lost for Words
There are still various other things that could cause it. Can you give us as much info as possible - Any black smoke? Any unusual behaviour? What warning lings and dash messages are you getting? Fault codes?
Fuel filter would be a favourite though, and a good place to start without fault codes. Thumbs Up Visiting from DISCO3.CO.UK
Post #480797 Tue Nov 24 2015 9:34am
jonesy_boys
hi, iv checked most of the electrics and other things such as damp ecu's. there is no smoke what soever, just loss of power and 'engine system fault' appears on the dash board. there are no warning lights on dash. ??? i dont have a clue.
Post #480818 Tue Nov 24 2015 5:04pm
Lost for Words
Yes, sounding a lot like a blocked fuel filter (or failing that, the LP fuel pump). Brake switch would be another possibility. Thumbs Up Visiting from DISCO3.CO.UK
Post #480820 Tue Nov 24 2015 5:24pm
jonesy_boys
thanks, il check the brake sensor. iv changed the fuel filter so it shouldn't be that but il double check.
Post #480821 Tue Nov 24 2015 5:36pm
jonesy_boys
sorry where would the brake switch be located?
Post #480822 Tue Nov 24 2015 5:37pm
Lost for Words
Top of the brake pedal. Thumbs Up
Easy to change, just make sure you don't release it before fitting or press the brake pedal when fitting:http://www.rrsport.co.uk/forum/topic30757.html
http://www.advancedfactors.co.uk/xkb500030...-738-p.asp
Post #480824 Tue Nov 24 2015 5:41pm
jonesy_boys
iv changed the brake switch this morning and checked over the electrics again and the 'engine system fault' still appears on the dash board and it wont rev over 5000 revs:(
Post #480863 Wed Nov 25 2015 12:04pm
Lost for Words
I think diagnostics are probably needed to get further now. Thumbs Up Visiting from DISCO3.CO.UK
Post #480864 Wed Nov 25 2015 12:36pm
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
How high does a TDV6 normally rev?
Post #480877 Wed Nov 25 2015 6:24pm
Gilly1
Hi, my tdv6 only revs to 4000rpm that's reving it in park and in drive it changes gear at 4000 rpm when I floor it, I haven't tried it in manual mode, would really like to no if this is normal, drives good and doesn't lack in power....
Post #480899 Wed Nov 25 2015 10:42pm
Paulcp
That is the norm for the tdv6, i was just intrigued by the 5000rpm comment Wink Wink
Post #480907 Thu Nov 26 2015 9:55am
